跳转到主内容
Asus Q504UA-BHI5T13 Display Assembly Replacement
你所需要的
  1. Asus Q504UA-BHI5T13 Display Assembly Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 5 中的图像 1,1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Display Assembly Replacement, Display Assembly: 步骤 6 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the six 5.00 mm screws connected to the hinges of the display assembly.
  7. Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 7 中的图像 1,3 Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 7 中的图像 2,3 Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 7 中的图像 3,3
    • Remove the two connectors with your hands, as shown.
  8. Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 8 中的图像 1,2 Asus Q504UA-BHI5T13 Display Assembly Replacement: 步骤 8 中的图像 2,2
    • Hold the display assembly with two hands and pull upwards to remove.
结论
2等其他人完成本指南。
Jacob Fritsch
于11/04/19注册
337 声望
创作了3篇指南
团队
IUPUI, Team S1-G2, Henning Fall 2019 IUPUI, Team S1-G2, Henning Fall 2019 的会员
IUPUI-HENNING-F19S1G2
3 名成员
创作了3篇指南
一条评论
Is this call soemthing else. I cannot find the complete assembly. My hinges are broken off and the front black bottom is split so I would like to have the entire assembly so that I could replace it all.
smej - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,258
