跳转到主内容
Asus Q504UA-BHI5T13 Battery Replacement
你所需要的
  1. Asus Q504UA-BHI5T13 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Battery Replacement: 步骤 5 中的图像 1,1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Battery Replacement: 步骤 7 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Battery Replacement: 步骤 8 中的图像 1,2 Asus Q504UA-BHI5T13 Battery Replacement: 步骤 8 中的图像 2,2
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Battery Replacement: 步骤 9 中的图像 1,2 Asus Q504UA-BHI5T13 Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the battery from the device.
结论
6等其他人完成本指南。
Brielle
于10/02/17注册
205 声望
撰写一个指南
团队
USF Tampa, Team S10-G4, Thompson Fall 2017 USF Tampa, Team S10-G4, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G4
4 名成员
创作了5篇指南
一条评论
Anyone know where to purchase this battery. I’ve ordered off ebay only to get a non-fitting battery and have scoured the internet only to come up empty handed. Any help appreciated.
Rick Grinstead - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 46
总计 5,271
