跳转到主内容
Asus Q504UA-BHI5T13 Back Panel Replacement
你所需要的
  1. Asus Q504UA-BHI5T13 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Back Panel Replacement: 步骤 2 中的图像 1,1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Back Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Back Panel Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Back Panel Replacement: 步骤 5 中的图像 1,1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
结论
3等其他人完成本指南。
Johnathan Teav
于10/02/17注册
456 声望
创作了3篇指南
团队
USF Tampa, Team S10-G4, Thompson Fall 2017 USF Tampa, Team S10-G4, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 955
