跳转到主内容
加入维修社区 - 创建账户
Asus Q503UA Battery Replacement
你所需要的
  1. Asus Q503UA Battery  Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA Battery  Replacement: 步骤 2 中的图像 1,2 Asus Q503UA Battery  Replacement: 步骤 2 中的图像 2,2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA Battery  Replacement: 步骤 3 中的图像 1,3 Asus Q503UA Battery  Replacement: 步骤 3 中的图像 2,3 Asus Q503UA Battery  Replacement: 步骤 3 中的图像 3,3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA Battery  Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the five screws holding the battery in place using a Phillips #0 screwdriver.
    • Screw locations are approximate. If you find screws to be located elsewhere, please update this step with their correct locations.
  5. Asus Q503UA Battery  Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery connection.
  6. Asus Q503UA Battery  Replacement: 步骤 6 中的图像 1,1
    • Grab and lift the battery from the top right-hand side.
    • If all screws are removed, it should come out with no struggle at all.
结论
3等其他人完成本指南。
Roberto Apodaca
于08/26/19注册
342 声望
创作了2篇指南
团队
Gateway, Team S1-G4, Saknee Fall 2019 Gateway, Team S1-G4, Saknee Fall 2019 的会员
GCC-SAKNEE-F19S1G4
4 名成员
创作了5篇指南
1指南评论
Great Instruction. Too bad reasonably priced replacements are no longer available new. I spent hours on the net using numerous search engines, The only new ones were in the hundreds of dollars, and who wants to buy used ones?
Don Dattler - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 58
总计 3,429
