跳转到主内容
Asus Q502LA-BSI5T14 Motherboard Replacement
你所需要的
  1. Asus Q502LA-BSI5T14 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 3 中的图像 1,2 Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 3 中的图像 2,2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 4 中的图像 1,2 Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 6 中的图像 1,2 Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 9 中的图像 1,2 Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Gently lift the motherboard out and away from the laptop.
结论
3等其他人完成本指南。
Mary Kounelas
于09/25/17注册
715 声望
创作了5篇指南
团队
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,583
