简介
The keyboard allows communication between the user and the laptop. If your keyboard is not responding, follow this guide to learn how to replace it.
你所需要的
Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
Using a plastic opening tool, lift the battery straight upward to remove it.
I would like to know if the connector needs to slide out to the right or if it also needs to pop out the top away from the motherboard?
The connector lifts straight up. Use a thin flat plastic tool, like the Ifixit opening tool, to gently pry under each end of the connector and it’ll pop off.
Before I take this on…more details on the wires??? With connectors or what?
Remove the one 5 mm Phillips #1 screw.
Pull out the green plastic in order to free the keyboard underneath.
另外一个人完成了本指南。
一条评论
Step 4 was misleading. It should have unplugged the cable before lifting the battery. I broke my battery connector off the mobo by following these directions. Lift straight up? That’s silly given how short the battery connection cable is.
Q504UA notebook has two hidden screws under back two slider pads making it 12 screws total to open not 10
Curtis Davis - 回复
