跳转到主内容
Asus Q502LA-BSI5T14 Fan Replacement
你所需要的
  1. Asus Q502LA-BSI5T14 Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Make sure your device is powered off before you begin.
    • Flip the laptop over and remove the ten 11 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Fan Replacement: 步骤 2 中的图像 1,1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Fan Replacement: 步骤 3 中的图像 1,1
    • Remove the eight 5 mm Phillips #1 screws securing the fan and copper piece to the motherboard.
    • Remove the wires by gently pulling them out.
  4. Asus Q502LA-BSI5T14 Fan Replacement: 步骤 4 中的图像 1,1
    • Gently lift the fan up and away from the laptop.
结论
另外一个人完成了本指南。
Mary Kounelas
于09/25/17注册
715 声望
创作了5篇指南
团队
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 367
