跳转到主内容
Asus Q502LA-BSI5T14 Battery Replacement
你所需要的
  1. Asus Q502LA-BSI5T14 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Battery Replacement: 步骤 3 中的图像 1,2 Asus Q502LA-BSI5T14 Battery Replacement: 步骤 3 中的图像 2,2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Battery Replacement: 步骤 4 中的图像 1,2 Asus Q502LA-BSI5T14 Battery Replacement: 步骤 4 中的图像 2,2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
结论
4等其他人完成本指南。
Mary Kounelas
于09/25/17注册
715 声望
创作了5篇指南
团队
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G1
4 名成员
创作了5篇指南
2条评论
Got as far as the removal from wires. How is that done. A total newbie. I just lifted the battery slightly. Would this help with the static or do I totally need to remove the battery? Laptop shows battery is almost fully charged. There is not a green light.
Berta Stoffel - 回复
Mine has no green light at first but after battery reaches full state it is there. However annoyingly flickers (screen and all) between charge state and discharging at full. Luckily seems to work fine across the whole range of charging. Can't believe this Q502LA is still holding on after 8 years :) Wondering if there is any battery drive/update?
jsbenami - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 4,410
