跳转到主内容
Asus Q501LA-BBI6T03 Wireless Card Replacement
你所需要的
  1. Asus Q501LA-BBI6T03 Wireless Card Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Wireless Card Replacement: 步骤 3 中的图像 1,2 Asus Q501LA-BBI6T03 Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • Pull up on the two metal tabs attached to the card .
    • Unscrew the single 2mm Phillips #0 screw in the top right hand corner.
  5. Asus Q501LA-BBI6T03 Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Gently slide the card out of its connection ports.
    • Make sure to pull straight out of the connection ports to avoid bending of the card or port.
结论
Once finished, follow prerequisite guide in reverse order to finish your repair.
3等其他人完成本指南。
Aodhan Arias
于01/25/17注册
288 声望
创作了2篇指南
团队
Cal Poly, Team 8-1, Banghart Winter 2017 Cal Poly, Team 8-1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G1
3 名成员
创作了6篇指南
2条评论
My Asus Q501L laptop cannot start the wifi card despite having updated the driver and restarting. Troubleshooting returns error Code 10. Did you experience or know how to resolve this problem?
Tony Ly - 回复
Hey there Tony,
I would recommend first checking the status of the hardware device first. You can view a device's status from the device's Properties in Device Manager. It is possible that the driver is corrupted even though it is “updated” fully and could be causing the issue. If so, remove and reinstall the drivers for the device. It could also be that the WiFi card has a hardware issue. There isn’t really anything I know of that you can do besides just replacing it if that’s the case. If it’s new it might be under warrantee but who knows. Unfortunately Code 10 errors are pretty vague and don’t really give a lot of information. Hope this helps.
Aodhan Arias -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 964
