简介
If your laptop is running hot, you may decide to either replace or clean out your fan unit, and replace the thermal compound with better quality.
你所需要的
Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
Remove the seven 4mm Phillips #0 screws holding the heat sink/fan assembly onto the motherboard.
即将完成!
结论
另外一个人完成了本指南。
