跳转到主内容
Asus Q501LA-BBI6T03 Heat Sink Disassembly
你所需要的
  1. Asus Q501LA-BBI6T03 Heat Sink Disassembly, Back Panel: 步骤 1 中的图像 1,1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Heat Sink Disassembly: 步骤 2 中的图像 1,1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Heat Sink Disassembly: 步骤 3 中的图像 1,2 Asus Q501LA-BBI6T03 Heat Sink Disassembly: 步骤 3 中的图像 2,2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Heat Sink Disassembly, Heat Sink/Fan Assembly: 步骤 4 中的图像 1,1
    • Remove the seven 4mm Phillips #0 screws holding the heat sink/fan assembly onto the motherboard.
  5. Asus Q501LA-BBI6T03 Heat Sink Disassembly: 步骤 5 中的图像 1,1
    • Using the spudger, unplug the fan from the motherboard connection by carefully pushing on both sides of the connector.
  6. Asus Q501LA-BBI6T03 Heat Sink Disassembly: 步骤 6 中的图像 1,1
    • Lift up on the fan, copper heat pipe and heat sink assembly, and remove from motherboard.
    • Be careful when removing the heat sink unit from the CPU, as there will be thermal paste residue that will have be to cleaned and new thermal paste applied.
结论
另外一个人完成了本指南。
Kyle Nagao
于01/25/17注册
366 声望
创作了2篇指南
团队
Cal Poly, Team 8-1, Banghart Winter 2017 Cal Poly, Team 8-1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 776
