跳转到主内容
Asus Q501LA-BBI6T03 Battery Replacement
你所需要的
  1. Asus Q501LA-BBI6T03 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Battery Replacement: 步骤 3 中的图像 1,2 Asus Q501LA-BBI6T03 Battery Replacement: 步骤 3 中的图像 2,2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the five silver 4mm Phillips #0 screws holding the battery to the laptop.
  5. Asus Q501LA-BBI6T03 Battery Replacement: 步骤 5 中的图像 1,1
    • Using the spudger, carefully remove the power cable connecting the battery to the rest of the laptop.
  6. Asus Q501LA-BBI6T03 Battery Replacement: 步骤 6 中的图像 1,1
    • Once the screws and cable are removed, carefully lift the battery from the laptop.
结论
7等其他人完成本指南。
Kyle Nagao
于01/25/17注册
366 声望
创作了2篇指南
团队
Cal Poly, Team 8-1, Banghart Winter 2017 Cal Poly, Team 8-1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 5,556
