跳转到主内容
Asus Q500A Hard Drive Replacement
你所需要的
  1. Asus Q500A Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Flip device onto backside
  2. Asus Q500A Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use a J0 screwdriver bit to remove both screws on the back-plate, found at the bottom of device.
    • Remove back-plate.
    • Note: Use prying tool if your having issues lifting back-plate.
  3. Asus Q500A Hard Drive Replacement: 步骤 3 中的图像 1,2 Asus Q500A Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Remove 4 screws from the metal hard-drive case. There will be one in each corner.
    • Remove the hard-drive case from the device.
  4. Asus Q500A Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the hard-drive. It will be connected to the integrated sata-port in the device.
    • Place hard-drive into slot and connect to the integrated sata port.
    • Place hard drive case back on top of the new hard-drive.
    • Screw in the four screws on the hard-drive case.
  5. Asus Q500A Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Place back-plate back on device.
    • Screw in the 2 screws on the back of the plate.
结论
2等其他人完成本指南。
cameron
于02/15/17注册
319 声望
创作了3篇指南
团队
USF Tampa, Team 12-5, Eyestone Spring 2017 USF Tampa, Team 12-5, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G5
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 991
