跳转到主内容
Asus Q500A Battery Replacement
  1. Asus Q500A Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip device onto backside.
  2. Asus Q500A Battery Replacement: 步骤 2 中的图像 1,1
    • Locate the two sliding locks.
    • Slide the sliding lock 1 to the right to unlock it .
    • There should be a red marker to indicate that it is unlocked. This lock will stay unlocked until slid back into the locked position.
  3. Asus Q500A Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the sliding lock 2 to the left to unlock it.
    • There will not be any indicator that it is unlocked. This lock will relock if you do not continue to push it to the left.
  4. Asus Q500A Battery Replacement: 步骤 4 中的图像 1,1
    • While the first and second lock are unlocked, slide the battery out to remove it.
    • When reinserting the replacement battery, make sure to slide sliding lock 1 back into the locked position. Otherwise the battery may come loose.
结论
cameron
于02/15/17注册
319 声望
创作了3篇指南
团队
USF Tampa, Team 12-5, Eyestone Spring 2017 USF Tampa, Team 12-5, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G5
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 497
