工具
配件
没有特定配件。
Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
Six 9.6 mm screws
Four 4.6 mm screws
Push metal bracket away from battery connector.
Use a spudger to push the battery connection straight up.
Remove the Phillips #0 screws that secure the battery to the lower case assembly
Three 4.7 mm screws.
**I am not responsible for any damages caused by any attempts at this repair. Use at your own risk.
另外一个人完成了本指南。
