跳转到主内容
Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement
你所需要的
  1. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: 步骤 1 中的图像 1,2 Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: 步骤 1 中的图像 2,2
    • Unscrew the ten 10mm Phillips #0 screws.
    • Use the plastic opening tool along the side of the laptop to pry open.
  2. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: 步骤 2 中的图像 1,2 Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 4mm Phillips #0 screws.
    • Gently pull the connector.
  3. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Lift the heat sink and fan assembly, and you are done!
    • There maybe a little resistance to being pulled up since the heat sink is attached to the CPU with thermal paste
结论
另外一个人完成了本指南。
团队
IUPUI, Team S1-G2, Hovde Fall 2018 IUPUI, Team S1-G2, Hovde Fall 2018 的会员
IUPUI-HOVDE-F18S1G2
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 128
