当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
To start, turn off the laptop and disconnect the power cable.
If the computer is on or plugged in, it could cause electric shock.
Flip the laptop over so the back panel is visible.
Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
Use an iFixit opening tool to lift the back cover and remove it from the laptop.
Remove the battery connector by using tweezers to lift up on it.
Remove the nine Phillips #00 screws that hold the battery in place.
There is one 9.2mm screw, four 4.7mm screws, and four 5.7mm screws.
Remove the battery from the battery bay.
取消:我没有完成这个指南。
与2其他贡献者
于09/16/19注册
689 声望
创作了6篇指南
徽章: 5
+ 2更多徽章
ERAU-SALAS-F19S8G2
3 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 306
