简介
If you’ve noticed that your laptop is not turning on, or maybe there is a problem with charging your Asus Q200E-CT144H laptop, use this guide to replace your battery/connector. The purpose of the battery/connector is to provide electricity in order to power on the laptop. If the battery goes to waste, then there is no way to operate the laptop, therefore making it useless as a whole. The Lithium-ion battery is an important component of the typical laptop.
你所需要的
To start, turn off the laptop and disconnect the power cable.
Flip the laptop over so the back panel is visible.
即将完成!
结论
