跳转到主内容
Asus Padfone X Mini Camera Replacement
你所需要的
  1. Asus Padfone X Mini Camera Replacement, Speaker: 步骤 1 中的图像 1,1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Camera Replacement: 步骤 2 中的图像 1,1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Camera Replacement: 步骤 3 中的图像 1,1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Camera Replacement: 步骤 4 中的图像 1,1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Camera Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove speaker with standard tweezers to minimize damage, and replace.
  6. Asus Padfone X Mini Camera Replacement, Screen: 步骤 6 中的图像 1,1
    • Detach the black connector on the left hand side of the motherboard.
    • Don't completely remove the black connector.
  7. Asus Padfone X Mini Camera Replacement: 步骤 7 中的图像 1,1
    • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
  8. Asus Padfone X Mini Camera Replacement: 步骤 8 中的图像 1,2 Asus Padfone X Mini Camera Replacement: 步骤 8 中的图像 2,2
    • Remove motherboard and replace screen.
  9. Asus Padfone X Mini Camera Replacement, Camera: 步骤 9 中的图像 1,1
    • Turn over the motherboard.
  10. Asus Padfone X Mini Camera Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers pull out the connector that connects the camera to the motherboard.
  11. Asus Padfone X Mini Camera Replacement: 步骤 11 中的图像 1,2 Asus Padfone X Mini Camera Replacement: 步骤 11 中的图像 2,2
    • Take out the camera.
    • Put in the new camera by sliding the camera connector into the receiver.
结论
James Jackson
于09/18/18注册
97 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 196
