跳转到主内容
Asus Padfone 2 Vibrator Replacement
你所需要的
  1. Asus Padfone 2 Vibrator Replacement, Power Down Device: 步骤 1 中的图像 1,1
    • Hold down the power button
  2. Asus Padfone 2 Vibrator Replacement, Remove Back Plate: 步骤 2 中的图像 1,3 Asus Padfone 2 Vibrator Replacement, Remove Back Plate: 步骤 2 中的图像 2,3 Asus Padfone 2 Vibrator Replacement, Remove Back Plate: 步骤 2 中的图像 3,3
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Vibrator Replacement, Battery Removal: 步骤 3 中的图像 1,3 Asus Padfone 2 Vibrator Replacement, Battery Removal: 步骤 3 中的图像 2,3 Asus Padfone 2 Vibrator Replacement, Battery Removal: 步骤 3 中的图像 3,3
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: 步骤 4 中的图像 1,2 Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: 步骤 4 中的图像 2,2
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: 步骤 5 中的图像 1,2 Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: 步骤 5 中的图像 2,2
    • Use tweezers to remove motor from housing, pulling the plug downward away from the phone.
    • Use tweezers to unplug the device from the circuit board.
结论
2等其他人完成本指南。
Zach Standridge
于09/25/14注册
350 声望
创作了2篇指南
团队
USF Tampa, Team 5-4, Mcgee Fall 2014 USF Tampa, Team 5-4, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,373
