跳转到主内容
Asus Padfone 2 Battery Replacement
你所需要的
  1. Asus Padfone 2 Battery Replacement, Power off phone: 步骤 1 中的图像 1,1
    • Hold down power button to shut off phone.
  2. Asus Padfone 2 Battery Replacement, Remove back cover of phone: 步骤 2 中的图像 1,2 Asus Padfone 2 Battery Replacement, Remove back cover of phone: 步骤 2 中的图像 2,2
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Battery Replacement, Battery Removal: 步骤 3 中的图像 1,3 Asus Padfone 2 Battery Replacement, Battery Removal: 步骤 3 中的图像 2,3 Asus Padfone 2 Battery Replacement, Battery Removal: 步骤 3 中的图像 3,3
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Disconnect battery connecting cord using tweezers.
结论
6等其他人完成本指南。
Zach Standridge
于09/25/14注册
350 声望
创作了2篇指南
团队
USF Tampa, Team 5-4, Mcgee Fall 2014 USF Tampa, Team 5-4, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G4
4 名成员
创作了7篇指南
一条评论
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 12
总计 5,866
