跳转到主内容
Asus PadFone S Battery Replacement
你所需要的
  1. Asus PadFone S Battery  Replacement, Remove the Back Panel: 步骤 1 中的图像 1,1
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Battery  Replacement, Remove the Back Panel: 步骤 2 中的图像 1,2 Asus PadFone S Battery  Replacement, Remove the Back Panel: 步骤 2 中的图像 2,2
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Battery  Replacement, Remove the Battery: 步骤 3 中的图像 1,2 Asus PadFone S Battery  Replacement, Remove the Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
结论
另外一个人完成了本指南。
Greg Betsold
于10/23/14注册
96 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 8,196
