跳转到主内容
Asus N56VM Motherboard Replacement
你所需要的
  1. 注意:步骤 1-2 源自标记为进行中的 指南
    Asus N56VM Motherboard Replacement, Remove battery: 步骤 1 中的图像 1,1
    • Remove the battery and the AC power
  2. Asus N56VM Motherboard Replacement, Remove bottom cover: 步骤 2 中的图像 1,2 Asus N56VM Motherboard Replacement, Remove bottom cover: 步骤 2 中的图像 2,2
    • Remove the M2x4 screw of the bottom cover
    • Remove the bottom cover by sliding it downwards
  3. 注意:步骤 3-4 源自标记为进行中的 指南
    Asus N56VM Motherboard Replacement, Optical drive: 步骤 3 中的图像 1,1
    • Remove the screw holding the optical drive
  4. Asus N56VM Motherboard Replacement: 步骤 4 中的图像 1,1
    • Pull out the optical drive
  5. 注意:步骤 5-6 源自标记为进行中的 指南
    Asus N56VM Motherboard Replacement, Hard Disk: 步骤 5 中的图像 1,2 Asus N56VM Motherboard Replacement, Hard Disk: 步骤 5 中的图像 2,2
    • Remove the screws
    • Remove the 3 M2x10 screws
    • Remove the one M2x4 screw
  6. Asus N56VM Motherboard Replacement: 步骤 6 中的图像 1,1
    • Gently pull the hard disk to the left
  7. Asus N56VM Motherboard Replacement, RAM: 步骤 7 中的图像 1,1
    • Remove the two RAM modules
    • Pop them out gently
    • Make sure you are electrostatically not loaded
  8. Asus N56VM Motherboard Replacement: 步骤 8 中的图像 1,1
    • Detach the two cables from the wireless module
  9. Asus N56VM Motherboard Replacement: 步骤 9 中的图像 1,2 Asus N56VM Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove all screws from the bottom cover
    • Remove 7 M2x10 screws
    • Remove 3 M2x4 screws
    • Remove 2 small screws
  10. Asus N56VM Motherboard Replacement: 步骤 10 中的图像 1,3 Asus N56VM Motherboard Replacement: 步骤 10 中的图像 2,3 Asus N56VM Motherboard Replacement: 步骤 10 中的图像 3,3
    • Open the lid of the notebook
    • Use a plastic opening tool to pry the bottom case
    • Be very careful when opening so that the cables in the case are not severed.
  11. Asus N56VM Motherboard Replacement: 步骤 11 中的图像 1,1
    • The motherboard is still connected to the bottom case by several cables, so don't try to remove it entirely just yet.
    • Hold the upper part with one hand, and use your other hand to disconnect the black&white cable (antenna for the wifi card)
  12. Asus N56VM Motherboard Replacement: 步骤 12 中的图像 1,1
    • Continue to hold the upper part with one hand, and use your other hand to disconnect the black ribbon cable
    • Remove the upper part with the motherboard
  13. Asus N56VM Motherboard Replacement: 步骤 13 中的图像 1,2 Asus N56VM Motherboard Replacement: 步骤 13 中的图像 2,2
    • This component is attached by a cable to the lower side of the motherboard therefore it is advised to remove it.
    • Remove the two screws holding the VGA IC
    • Lift the IC
  14. Asus N56VM Motherboard Replacement: 步骤 14 中的图像 1,3 Asus N56VM Motherboard Replacement: 步骤 14 中的图像 2,3 Asus N56VM Motherboard Replacement: 步骤 14 中的图像 3,3
    • Remove the cable by first lifting the black holder and then removing the cable
  15. Asus N56VM Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the white cable simply by pulling it out from the connector
  16. Asus N56VM Motherboard Replacement: 步骤 16 中的图像 1,3 Asus N56VM Motherboard Replacement: 步骤 16 中的图像 2,3 Asus N56VM Motherboard Replacement: 步骤 16 中的图像 3,3
    • Remove the touchpad cable by first lifting the black holder
  17. Asus N56VM Motherboard Replacement: 步骤 17 中的图像 1,3 Asus N56VM Motherboard Replacement: 步骤 17 中的图像 2,3 Asus N56VM Motherboard Replacement: 步骤 17 中的图像 3,3
    • Remove the two keyboard cables by first pulling out the black holders. After that the cables are released
  18. Asus N56VM Motherboard Replacement: 步骤 18 中的图像 1,2 Asus N56VM Motherboard Replacement: 步骤 18 中的图像 2,2
    • Remove the four screws holding the motherboard
    • Remove the screw holding the fan
    • Pry out the plastic thing holding the motherboard in place
结论
另外一个人完成了本指南。
Stanky
于07/08/17注册
1,098 声望
创作了6篇指南
2条评论
Can you please help me locate the gpu VRM on the motherboard? My gpu is faulty and needs to be rebonded, so I wanna permanently disable it.
Coll Student - 回复
Sorry, I can’t help you with that
Stanky -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 27
总计 3,221
