跳转到主内容
Asus MeMo Pad 10 ME102A Battery Replacement
你所需要的
  1. Asus MeMo Pad 10 ME102A Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
    • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
  2. Asus MeMo Pad 10 ME102A Battery Replacement: 步骤 2 中的图像 1,1
    • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
  3. Asus MeMo Pad 10 ME102A Battery Replacement: 步骤 3 中的图像 1,1
    • After all of the clips have been opened, the back panel should be free to remove by hand
  4. Asus MeMo Pad 10 ME102A Battery Replacement, Battery: 步骤 4 中的图像 1,2 Asus MeMo Pad 10 ME102A Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Unplug the blue ribbon cable which runs across the top of the battery near the left-hand speaker. It connects by plugging into a white and black plug on each side. To unplug the ribbon cable, gently pull up the black tabs with the small plastic opening tool.
  5. Asus MeMo Pad 10 ME102A Battery Replacement: 步骤 5 中的图像 1,2 Asus MeMo Pad 10 ME102A Battery Replacement: 步骤 5 中的图像 2,2
    • Unplug the battery cable located on the opposite side of the battery. Use the plastic opening tool to gently push it out of the socket on the motherboard.
  6. Asus MeMo Pad 10 ME102A Battery Replacement: 步骤 6 中的图像 1,3 Asus MeMo Pad 10 ME102A Battery Replacement: 步骤 6 中的图像 2,3 Asus MeMo Pad 10 ME102A Battery Replacement: 步骤 6 中的图像 3,3
    • Separate the battery from the chassis by sliding the nylon spudger under the battery along the 3 glue strips. The glue needs to be gradually separated. The battery will lift free once the glue has been separated.
    • There are 3 glue strips holding the battery to the chassis: One under the blue ribbon cable, one under the center of the battery, and one under the battery by the plug.
    • While slight deformation is normal, do not overly bend the battery.
    • The glue needs to be gradually separated. Slow, persistent work with the spudger will be effective but can take an extended period of time.
结论
2等其他人完成本指南。
Noah Peseckis
于09/15/16注册
150 声望
撰写一个指南
团队
USF Tampa, Team 11-3, Blackwell Fall 2016 USF Tampa, Team 11-3, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G3
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 5,477
