跳转到主内容
Asus MeMo Pad 10 ME102A Back Panel Replacement
你所需要的
  1. Asus MeMo Pad 10 ME102A Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
    • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
  2. Asus MeMo Pad 10 ME102A Back Panel Replacement: 步骤 2 中的图像 1,1
    • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
  3. Asus MeMo Pad 10 ME102A Back Panel Replacement: 步骤 3 中的图像 1,1
    • After all of the clips have been opened, the back panel should be free to remove by hand
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 11-3, Blackwell Fall 2016 USF Tampa, Team 11-3, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 1,764
