跳转到主内容
Asus MeMO Pad HD 7 Battery Replacement
你所需要的
  1. Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 步骤 1 中的图像 1,3 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 步骤 1 中的图像 2,3 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 步骤 1 中的图像 3,3
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
  2. Asus MeMO Pad HD 7 Battery Replacement: 步骤 2 中的图像 1,1
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7 Battery Replacement: 步骤 3 中的图像 1,1
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 步骤 4 中的图像 1,3 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 步骤 4 中的图像 2,3 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 步骤 4 中的图像 3,3
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
结论
14等其他人完成本指南。
Julien Daigle
于01/20/15注册
1,235 声望
创作了5篇指南
团队
USF Tampa, Team 11-3, Blackwell Winter 2015 USF Tampa, Team 11-3, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G3
4 名成员
创作了5篇指南
4条评论
Make sure you REMOVE the micro SD card prior to opening it! Otherwise you risk damaging the micro SD card port.
I just opened my tablet to change the battery, didn't realize this, and sure enough, broke it :(
Hope this helps you avoid that mistake.
dpietros - 回复
How did you fix the sd card port?
yanisstavrou - 回复
It is VERY important that you do not bend the battery during removal!! Even more advisable is discharging the battery completely prior to replacement.... I accidentally bent the old battery while attempting to remove it and the battery heated up, bulged and then exploded!
Eric - 回复
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
chattyubante - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 29
总计 21,556
