跳转到主内容
Asus MeMO Pad 8 ME181C Speaker Assembly Replacement
你所需要的
  1. Asus MeMO Pad 8 ME181C Speaker Assembly Replacement, Rear Case: 步骤 1 中的图像 1,2 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Speaker Assembly Replacement, Battery: 步骤 2 中的图像 1,3 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement, Battery: 步骤 2 中的图像 2,3 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement, Battery: 步骤 2 中的图像 3,3
    • Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
  3. Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 3 中的图像 1,2 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 3 中的图像 2,2
    • Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
  4. Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 4 中的图像 1,2 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 4 中的图像 2,2
    • Use the pointed end of the nylon spudger to pop up the battery connector.
    • When reconnecting the battery cable after replacing the battery, press the battery connector with your finger until it clicks into place.
  5. Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 5 中的图像 1,2 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 5 中的图像 2,2
    • Use the flat end of the nylon spudger to pry up the battery.
    • The battery is secured with adhesive. Some force is required to detach battery from the device.
    • If removing motherboard is necessary, it may be easier complete this step with the motherboard simultaneously later.
  6. Asus MeMO Pad 8 ME181C Speaker Assembly Replacement, Speaker Assembly: 步骤 6 中的图像 1,3 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement, Speaker Assembly: 步骤 6 中的图像 2,3 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement, Speaker Assembly: 步骤 6 中的图像 3,3
    • Use the pointed end of a spudger to disconnect the speaker cable.
    • Gently pull the speaker cable out of its channel along the left side of the device.
  7. Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 7 中的图像 1,1
    • Remove the four 3 mm Phillips #000 screws securing the speaker assembly.
  8. Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 8 中的图像 1,2 Asus MeMO Pad 8 ME181C Speaker Assembly Replacement: 步骤 8 中的图像 2,2
    • Remove the speaker assembly from the device.
结论
Geoff Wacker
于09/30/13注册
90,313 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 427
