跳转到主内容
Asus MeMO Pad 8 ME181C Battery Replacement
你所需要的
  1. Asus MeMO Pad 8 ME181C Battery Replacement, Rear Case: 步骤 1 中的图像 1,2 Asus MeMO Pad 8 ME181C Battery Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Battery Replacement, Battery: 步骤 2 中的图像 1,3 Asus MeMO Pad 8 ME181C Battery Replacement, Battery: 步骤 2 中的图像 2,3 Asus MeMO Pad 8 ME181C Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
  3. Asus MeMO Pad 8 ME181C Battery Replacement: 步骤 3 中的图像 1,2 Asus MeMO Pad 8 ME181C Battery Replacement: 步骤 3 中的图像 2,2
    • Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
  4. Asus MeMO Pad 8 ME181C Battery Replacement: 步骤 4 中的图像 1,2 Asus MeMO Pad 8 ME181C Battery Replacement: 步骤 4 中的图像 2,2
    • Use the pointed end of the nylon spudger to pop up the battery connector.
    • When reconnecting the battery cable after replacing the battery, press the battery connector with your finger until it clicks into place.
  5. Asus MeMO Pad 8 ME181C Battery Replacement: 步骤 5 中的图像 1,2 Asus MeMO Pad 8 ME181C Battery Replacement: 步骤 5 中的图像 2,2
    • Use the flat end of the nylon spudger to pry up the battery.
    • The battery is secured with adhesive. Some force is required to detach battery from the device.
    • If removing motherboard is necessary, it may be easier complete this step with the motherboard simultaneously later.
结论
7等其他人完成本指南。
Amy Clarke
于05/05/16注册
223 声望
创作了2篇指南
团队
iFixit, Team 1-1, Wacker Spring 2016 iFixit, Team 1-1, Wacker Spring 2016 的会员
FIX-WACKER-S16S1G1
3 名成员
创作了4篇指南
2条评论
Great instructions and easy disassembly/reassembly. Photos really helped!
Joe Martin - 回复
The time and difficulty for doing this and the me176cx should be the same.
P Schmied - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 5,237
