跳转到主内容
Asus MeMO Pad 7 ME176C Speaker Replacement
你所需要的
  1. Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: 步骤 1 中的图像 1,2 Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    购买
    • Make sure the device is turned off.
    • Carefully insert the opening tool on the edge of the phone.
    • Slowly lift up the panel from the device and repeat the process on the other side.
  2. Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 2 中的图像 1,3 Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 2 中的图像 2,3 Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 2 中的图像 3,3
    • To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
    • ZIF connectors are fragile, so work with caution.
  3. Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 3 中的图像 1,3 Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 3 中的图像 2,3 Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 3 中的图像 3,3
    • The battery connector is located on the right-hand side of the device
    • To disconnect the battery connector. Use tweezers, and carefully lift up the wire.
    • Remove the battery.
  4. Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 4 中的图像 1,1
    • Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
    • Place these screws somewhere you will remember.
    • Applying too much pressure onto the screen may cause it to break.
  5. Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 5 中的图像 1,3 Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 5 中的图像 2,3 Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 5 中的图像 3,3
    • Using tweezers, disconnect the speaker cable connected to the motherboard.
    • Be sure not to damage other components on the motherboard.
    • After that remove the speaker system completely.
  6. Asus MeMO Pad 7 ME176C Speaker Replacement: 步骤 6 中的图像 1,1
    • Now you can attach a new speaker!
结论
Maxime
于09/26/17注册
101 声望
撰写一个指南
团队
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G3
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 230
