跳转到主内容
Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
你所需要的
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: 步骤 1 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: 步骤 1 中的图像 2,2
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 2 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 5 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 5 中的图像 2,2
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 6 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 6 中的图像 2,2
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 7 中的图像 1,3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 7 中的图像 2,3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 7 中的图像 3,3
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 8 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 8 中的图像 2,2
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 9 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 9 中的图像 2,2
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 10 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 10 中的图像 2,2
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 11 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 11 中的图像 2,2
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 12 中的图像 1,3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 12 中的图像 2,3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 12 中的图像 3,3
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
结论
Nejad Harara
于09/26/17注册
110 声望
撰写一个指南
团队
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G3
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 15
总计 1,692
