跳转到主内容
Asus MeMO Pad 7 ME176C Battery Replacement
你所需要的
  1. Asus MeMO Pad 7 ME176C Battery Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Make sure the device is turned off.
    • Use a plastic opening tool to remove the back panel by carefully moving the tool around the back cover of the device until it comes off.
  2. Asus MeMO Pad 7 ME176C Battery Replacement: 步骤 2 中的图像 1,2 Asus MeMO Pad 7 ME176C Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the black bundle connector on the back of the device. Gently slide the plastic tool underneath the black bundle cable connector towards the battery until it comes off.
  3. Asus MeMO Pad 7 ME176C Battery Replacement: 步骤 3 中的图像 1,3 Asus MeMO Pad 7 ME176C Battery Replacement: 步骤 3 中的图像 2,3 Asus MeMO Pad 7 ME176C Battery Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opener tool, carefully remove the ZIF connectors that is covering the battery.
  4. Asus MeMO Pad 7 ME176C Battery Replacement: 步骤 4 中的图像 1,3 Asus MeMO Pad 7 ME176C Battery Replacement: 步骤 4 中的图像 2,3 Asus MeMO Pad 7 ME176C Battery Replacement: 步骤 4 中的图像 3,3
    • Wedge the flat end of a spudger or plastic opening tool under the battery to free the battery form any adhesives.
    • Do not bend or puncture the battery.
结论
3等其他人完成本指南。
团队
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G3
5 名成员
创作了9篇指南
一条评论
It might be better to remove the whole aluminum tray under the battery. It is really tough to slice the tape holding the battery to the tray without bending up the battery or putting a lot of pressure on the circuit board. It looks like nine screws and a couple extra steps.
Jim80686 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 2,203
