跳转到主内容
Asus MeMO Pad 7 ME170C Speaker Replacement
你所需要的
  1. Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Before beginning to disassemble the device, power it off.
    • Make sure to be gentle with the device. Excessive force can result in a damaged screen.
    • Using the Jimmy tool, gently wedge it into the seam of the device at the side.
    • Pry the Jimmy tool gently all around the seam. Use up and down motions until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C Speaker Replacement: 步骤 2 中的图像 1,3 Asus MeMO Pad 7 ME170C Speaker Replacement: 步骤 2 中的图像 2,3 Asus MeMO Pad 7 ME170C Speaker Replacement: 步骤 2 中的图像 3,3
    • From the top of the tablet, locate the white cable connector.
    • It is inserted in a black port on the motherboard.
    • Use the blue plastic opening tool to push the white cable connector out of the port.
    • Push the cable in a sideways motion towards the top of the device.
  3. Asus MeMO Pad 7 ME170C Speaker Replacement: 步骤 3 中的图像 1,2 Asus MeMO Pad 7 ME170C Speaker Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips #000 screwdriver to remove the seven screws.
    • There should be two silver and five black screws for a total of seven screws.
  4. Asus MeMO Pad 7 ME170C Speaker Replacement: 步骤 4 中的图像 1,2 Asus MeMO Pad 7 ME170C Speaker Replacement: 步骤 4 中的图像 2,2
    • Use the slender, metal spudger tool to gently lift up the edge of the speaker to remove the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 680
