跳转到主内容
Asus MeMO Pad 7 ME170C Battery Replacement
你所需要的
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: 步骤 1 中的图像 1,3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: 步骤 1 中的图像 2,3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: 步骤 2 中的图像 1,3 Asus MeMO Pad 7 ME170C  Battery Replacement: 步骤 2 中的图像 2,3 Asus MeMO Pad 7 ME170C  Battery Replacement: 步骤 2 中的图像 3,3
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: 步骤 3 中的图像 1,3 Asus MeMO Pad 7 ME170C  Battery Replacement: 步骤 3 中的图像 2,3 Asus MeMO Pad 7 ME170C  Battery Replacement: 步骤 3 中的图像 3,3
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 3,101
