简介
The ribbon cable acts as a bundling unit to hold multiple wires together. Basically, instead of having a bunch of cords in random places, the ribbon holds them together as one, clean unit.
你所需要的
Using the Jimmy tool, pry it into the seam of the device.
With the Jimmy tool, pry open the device through the seam.
Using wide nosed tweezers, pinch the blue tab attached to the ribbon cable towards the top of the device that is inserted in the mother board.
In a lateral motion, pull the blue tab gently.
At the bottom of the device, use wide nosed tweezers to pinch the opposite blue tab of the ribbon cable.
Heat the iOpener in the microwave for one minute.
After heating, vertically place the iOpener on top of the ribbon cable. Let it sit for one minute.
Remove the iOpener.
Use the wide nosed tweezers to pinch the ribbon cable from the middle. Pull it up firmly to detach. Be careful not to rip it off.
