跳转到主内容
Asus M51E-B2 Swivel Camera Replacement
你所需要的
  1. Asus M51E-B2  Swivel Camera Replacement, Swivel Camera: 步骤 1 中的图像 1,1
    • Open the laptop.
    • Press and hold the power button until the laptop powers off.
  2. Asus M51E-B2  Swivel Camera Replacement: 步骤 2 中的图像 1,2 Asus M51E-B2  Swivel Camera Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger prying tool to remove the outer screen cover of the laptop.
    • Gently work your way clockwise around the outer part of the screen.
  3. Asus M51E-B2  Swivel Camera Replacement: 步骤 3 中的图像 1,2 Asus M51E-B2  Swivel Camera Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips PH0 head screwdriver to remove the two 2.5 mm screws located on the left side of the camera.
    • Use the Phillips PH0 head screwdriver to remove the one 2.5 millimeter screw that goes through the left side of the camera.
  4. Asus M51E-B2  Swivel Camera Replacement: 步骤 4 中的图像 1,1
    • Find the wiring harness on the right side of the camera.
    • Using your fingers, gently remove the wiring harness connected to the right side of the camera.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 283
