简介
Use this guide to replace the fan in your Asus R510CA-OB01 laptop.
A Wi-Fi card acts as a gateway between the computer and your wireless network, allowing it to exchange data with other Wi-Fi devices.
Slow ping times and network disconnects may be the result of a faulty Wi-Fi card. Try resetting it and downloading drivers before installing a new one.
Before beginning, make sure to power off your computer. Disconnect it from any external power source. Remove dust build-up with a dust blower.
你所需要的
Press and slide the two battery retention clips on either side of the battery towards the unlock position.
Remove the white and black wires from the card.
This does not require much force. Simply squeeze on the sides of the connector and allow the end to pop off.
2等其他人完成本指南。
