跳转到主内容
Asus K55a-si50301p USB 3.0 Replacement
你所需要的
  1. Asus K55a-si50301p USB 3.0 Replacement, Battery: 步骤 1 中的图像 1,1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p USB 3.0 Replacement: 步骤 2 中的图像 1,1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p USB 3.0 Replacement: 步骤 3 中的图像 1,1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p USB 3.0 Replacement, USB 3.0/Audio Ports: 步骤 4 中的图像 1,1
    • Remove the eight Phillips #0 screws.
  5. Asus K55a-si50301p USB 3.0 Replacement: 步骤 5 中的图像 1,1
    • Gently pull towards yourself and up to remove the first plastic cover.
  6. Asus K55a-si50301p USB 3.0 Replacement: 步骤 6 中的图像 1,2 Asus K55a-si50301p USB 3.0 Replacement: 步骤 6 中的图像 2,2
    • Use the iFixit opening tool around the outside line where the top of the laptop meets the bottom to separate components.
  7. Asus K55a-si50301p USB 3.0 Replacement: 步骤 7 中的图像 1,1
    • Flip the laptop over and lift the keyboard tray gently towards the screen.
    • Remove the 3 ribbon cables from the motherboard end.
  8. Asus K55a-si50301p USB 3.0 Replacement: 步骤 8 中的图像 1,1
    • With the keyboard tray out of the way, remove the tape holding down the accessory board ribbon cable.
  9. Asus K55a-si50301p USB 3.0 Replacement: 步骤 9 中的图像 1,1
    • Pull the ribbon cable out of its slot on the USB/Audio port board as shown.
结论
另外一个人完成了本指南。
一条评论
after doing this start button lights up but will not boot
David Garside - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 681
