跳转到主内容
Asus K55a-si50301p RAM Replacement
你所需要的
  1. Asus K55a-si50301p RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p RAM Replacement: 步骤 2 中的图像 1,1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p RAM Replacement: 步骤 3 中的图像 1,1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p RAM Replacement, Lower Back Panel: 步骤 4 中的图像 1,1
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p RAM Replacement: 步骤 5 中的图像 1,1
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p RAM Replacement: 步骤 6 中的图像 1,1
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p RAM Replacement, RAM: 步骤 7 中的图像 1,1
    • Press slot pins outwards with gentle force.
  8. Asus K55a-si50301p RAM Replacement: 步骤 8 中的图像 1,1
    • After the RAM stick pops up, pull it towards you to gently remove it.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 11
总计 471
