简介
The Asus K55A-Si50301P RAM Replacement Guide explains the tools and processes used to replace/remove the RAM. RAM can become faulty from the manufacturer or could be damaged when put into its slot on the computer. If the RAM is damaged the computer will not be able to power on if you have one slot used or limit your ability to multitask if you have multiple RAM slots used. The Asus K55A-Si50301P Troubleshooting page may be referred to here as needed.
你所需要的
Press and slide the two battery retention clips on either side of the battery towards the unlock position.
2等其他人完成本指南。
