跳转到主内容
Asus K55a-si50301p Hard Drive Replacement
你所需要的
  1. Asus K55a-si50301p Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p Hard Drive Replacement, Lower Back Panel: 步骤 4 中的图像 1,1
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,2 Asus K55a-si50301p Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Remove the (3) screws that hold the hard drive to the case.
  8. Asus K55a-si50301p Hard Drive Replacement: 步骤 8 中的图像 1,2 Asus K55a-si50301p Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Disconnect the SATA link from the hard drive by pulling back on the grey connector.
  9. Asus K55a-si50301p Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the two screws from each side of the hard drive tray.
    • Replace the hard drive with a new 2.5" hard drive or solid state drive.
结论
4等其他人完成本指南。
一条评论
So the link you give for the replacement hard drive is for a 3.5 inch drive instead of a 2.5 inch drive
sweal - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 1,110
