跳转到主内容
Asus K55a-si50301p Battery Replacement
  1. Asus K55a-si50301p Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Battery Replacement: 步骤 2 中的图像 1,1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Battery Replacement: 步骤 3 中的图像 1,1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 665
