跳转到主内容
加入维修社区 - 创建账户
Asus K55VD RAM Replacement
你所需要的
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  1. Asus K55VD RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • To access the compartment that holds the RAM, flip the laptop so the bottom cover is facing upward and the battery compartment is facing away from you.
  2. Asus K55VD RAM Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the two screws that hold down the compartment cover.
  3. Asus K55VD RAM Replacement: 步骤 4 中的图像 1,1
    • Lift the cover and locate the green and blue RAM sticks on the right side of the device.
  4. Asus K55VD RAM Replacement: 步骤 5 中的图像 1,3 Asus K55VD RAM Replacement: 步骤 5 中的图像 2,3 Asus K55VD RAM Replacement: 步骤 5 中的图像 3,3
    • To remove the green RAM stick, push outward on the inner sides of the two metal chip holders simultaneously.
    • Pull out the stick once it is released from the holders.
    • Repeat this step on the lower level that holds the blue RAM stick.
结论
4等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 537
过去 30 天: 1,353
总计 2,453
