简介
If a computer's fan is faulty, there will likely be overheating error messages occurring. If overheating does occur, the CPU could be damaged.
你所需要的
步骤 1 Battery
注意:步骤 1 源自标记为进行中的 指南。
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
After removing the screws, remove the smaller cover.
7等其他人完成本指南。
2条评论
At step 5, you should also unscrew the bottom silver screw and unplug the wifi antennas.
