跳转到主内容
Asus K55VD DVD Player Replacement
你所需要的
  1. 注意:步骤 1 源自标记为进行中的 指南
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  2. Asus K55VD DVD Player Replacement, Hard Drive: 步骤 2 中的图像 1,2 Asus K55VD DVD Player Replacement, Hard Drive: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  3. Asus K55VD DVD Player Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
    The bottom left screw does not hold down the drive bay. Unsrew that screw in step 5.
    Daniel - 回复
  4. Asus K55VD DVD Player Replacement: 步骤 4 中的图像 1,2 Asus K55VD DVD Player Replacement: 步骤 4 中的图像 2,2
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  5. Asus K55VD DVD Player Replacement, Optical Disk Drive: 步骤 5 中的图像 1,1
    • Using the the Philips #0 Screwdriver remove highlighted screws.
  6. Asus K55VD DVD Player Replacement: 步骤 6 中的图像 1,1
    • Lift plastic cover with tweezers.
    • Remove screw.
  7. Asus K55VD DVD Player Replacement: 步骤 7 中的图像 1,1
    • Lift keyboard panel with plastic pry tool to remove.
  8. Asus K55VD DVD Player Replacement: 步骤 8 中的图像 1,2 Asus K55VD DVD Player Replacement: 步骤 8 中的图像 2,2
    • Unhook all ribbons to remove keyboard panel completely.
  9. Asus K55VD DVD Player Replacement: 步骤 9 中的图像 1,2 Asus K55VD DVD Player Replacement: 步骤 9 中的图像 2,2
    • Slide the DVD Player outward.
结论
另外一个人完成了本指南。
一条评论
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
Luke Malatinsky - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,155
