跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
If your Asus K55VD is having problems reading DVDs, not playing audio or videos properly, or DVD programs won't install properly then it may be experiencing a faulty optical disk drive which needs to be replaced.
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  1. Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover. After removing the screws, remove the smaller cover.
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  2. Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
  3. Remove the hard drive from the slot. Remove the hard drive from its shell.
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  4. Using the the Philips #0 Screwdriver remove highlighted screws.
    • Using the the Philips #0 Screwdriver remove highlighted screws.
  5. Lift plastic cover with tweezers.
    • Lift plastic cover with tweezers.
    • Remove screw.
  6. Lift keyboard panel with plastic pry tool to remove.
    • Lift keyboard panel with plastic pry tool to remove.
  7. Unhook all ribbons to remove keyboard panel completely. Unhook all ribbons to remove keyboard panel completely.
    • Unhook all ribbons to remove keyboard panel completely.
  8. Slide the DVD Player outward. Slide the DVD Player outward.
    • Slide the DVD Player outward.
结论
Hector Morales
于2018年09月21日注册
123 信誉积分
撰写一个指南
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
Luke Malatinsky - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 18
总计 216
