跳转到主内容
Asus K55N-DS81 RAM Replacement
你所需要的
  1. Asus K55N-DS81 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Asus K55N-DS81 RAM Replacement: 步骤 2 中的图像 1,2 Asus K55N-DS81 RAM Replacement: 步骤 2 中的图像 2,2
    • Pull the latch to the right of the battery to the right.
  3. Asus K55N-DS81 RAM Replacement: 步骤 3 中的图像 1,2 Asus K55N-DS81 RAM Replacement: 步骤 3 中的图像 2,2
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. Asus K55N-DS81 RAM Replacement: 步骤 4 中的图像 1,2 Asus K55N-DS81 RAM Replacement: 步骤 4 中的图像 2,2
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Asus K55N-DS81 RAM Replacement, Rear Panel: 步骤 5 中的图像 1,2 Asus K55N-DS81 RAM Replacement, Rear Panel: 步骤 5 中的图像 2,2
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Asus K55N-DS81 RAM Replacement: 步骤 6 中的图像 1,3 Asus K55N-DS81 RAM Replacement: 步骤 6 中的图像 2,3 Asus K55N-DS81 RAM Replacement: 步骤 6 中的图像 3,3
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
  7. Asus K55N-DS81 RAM Replacement, RAM: 步骤 7 中的图像 1,2 Asus K55N-DS81 RAM Replacement, RAM: 步骤 7 中的图像 2,2
    • Lift up the plastic static shield atop the RAM slots.
  8. Asus K55N-DS81 RAM Replacement: 步骤 8 中的图像 1,2 Asus K55N-DS81 RAM Replacement: 步骤 8 中的图像 2,2
    • Depress the tongs on either side of the RAM stick to loosen the RAM from the slot.
  9. Asus K55N-DS81 RAM Replacement: 步骤 9 中的图像 1,2 Asus K55N-DS81 RAM Replacement: 步骤 9 中的图像 2,2
    • Grab the RAM and pull away from the slot to release it.
结论
另外一个人完成了本指南。
Elliott Beckner
于11/05/18注册
543 声望
创作了4篇指南
团队
IUPUI, Team S2-G1, Baechle Fall 2018 IUPUI, Team S2-G1, Baechle Fall 2018 的会员
IUPUI-BAECHLE-F18S2G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 378
