当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Flip the laptop over, such that the bottom of the laptop is facing upwards.
Ensure that the laptop is powered off prior to following this guide.
While holding the second latch from the previous step, use another hand to reach underneath the battery.
Pull the battery upwards and away from the laptop to remove it.
Grab the plastic tab located on the hard drive enclosure.
Pull the tab towards yourself, the hard drive will slide towards you as it disconnects from the motherboard.
Lift the enclosure by the tab to remove the enclosure from the laptop.
Using a JIS #00 screwdriver, unscrew the four 3 mm screws securing the hard drive to the enclosure.
Do not forget to flip the enclosure over and unscrew the screws on the other side.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
