跳转到主内容
Asus K53E-BBR7 Optical Drive Replacement
你所需要的
  1. Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,3 Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 2,3 Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 3,3
    • Push the two locking mechanisms at the top of your laptop away from each other.
    • Pull the battery away from your laptop using your hands.
    • The battery of this laptop is missing.
  2. Asus K53E-BBR7 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the two black 7.0 mm Phillips #0 screws from the back cover of your laptop.
  3. Asus K53E-BBR7 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the back panel by sliding the panel downwards with your hands.
  4. Asus K53E-BBR7 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Use your Phillips #0 screwdriver to remove the four 7.0 mm Phillips #0 screws surrounding the hard drive.
    • Use your hands to slowly pull the hard drive out of your laptop.
    • The hard drive of this laptop is missing.
  5. Asus K53E-BBR7 Optical Drive Replacement: 步骤 5 中的图像 1,2 Asus K53E-BBR7 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Using your Phillips #0 screwdriver, remove the following seventeen screws from your laptop:
    • Sixteen black 7.0 mm Phillips #0 screws
    • One silver 4.0 mm Phillips #0 screw
  6. Asus K53E-BBR7 Optical Drive Replacement: 步骤 6 中的图像 1,3 Asus K53E-BBR7 Optical Drive Replacement: 步骤 6 中的图像 2,3 Asus K53E-BBR7 Optical Drive Replacement: 步骤 6 中的图像 3,3
    • Flip the laptop over and open the lid to reveal the keyboard.
    • Insert the blue prying tool into each of the five tabs located at the top of the keyboard, pulling upwards on the keyboard to separate it from the palm rest.
    • Once the top of the keyboard has been separated from the device, slowly begin pulling the keyboard away from the laptop using your hands.
    • A silver ribbon cable is connected to the keyboard and the palm rest of the laptop. Removing the keyboard quickly may tear the silver ribbon cable, causing harm to your device.
  7. Asus K53E-BBR7 Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Using your fingers, gently disconnect the silver ribbon cable from the laptop by pulling the cable out of the slot and to the right.
    • When separating the ribbon cable from the laptop, be gentle. Improperly removing the ribbon cable from the device can damage the laptop.
  8. Asus K53E-BBR7 Optical Drive Replacement: 步骤 8 中的图像 1,2 Asus K53E-BBR7 Optical Drive Replacement: 步骤 8 中的图像 2,2
    • Remove the single silver 6.0 mm Phillips #0 screw that connects the optical drive to the palm rest.
  9. Asus K53E-BBR7 Optical Drive Replacement: 步骤 9 中的图像 1,2 Asus K53E-BBR7 Optical Drive Replacement: 步骤 9 中的图像 2,2
    • Remove the optical drive from the laptop by pulling it to the right with your hands.
结论
2等其他人完成本指南。
团队
UW Tacoma, Team 1-3, Rose Fall 2016 UW Tacoma, Team 1-3, Rose Fall 2016 的会员
UWT-ROSE-F16S1G3
4 名成员
创作了4篇指南
一条评论
Most of these steps are unnecessary to get to the dvd-drive. The keyboard clicks loose without removing these screws too, so only steps 7, 8 and 9 are needed.
Nick - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 2,794
