跳转到主内容
Asus K53E-BBR7 Keyboard Replacement
你所需要的
  1. Asus K53E-BBR7 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Asus K53E-BBR7 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Asus K53E-BBR7 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Turn off the device.
    • Disconnect the charging cable if applicable.
    • Push the two locking mechanisms away from the center of the device and slowly remove the battery.
  2. Asus K53E-BBR7 Keyboard Replacement: 步骤 2 中的图像 1,3 Asus K53E-BBR7 Keyboard Replacement: 步骤 2 中的图像 2,3 Asus K53E-BBR7 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Insert the blue prying tool into each of the five tabs at the top of your keyboard, moving from the outer edge inward. Use the blue prying tool to separate the keyboard from the palm rest.
    • Use your hand to gently pull the keyboard away from the laptop.
  3. Asus K53E-BBR7 Keyboard Replacement: 步骤 3 中的图像 1,2 Asus K53E-BBR7 Keyboard Replacement: 步骤 3 中的图像 2,2
    • As the keyboard comes loose, gently lift the board up so the bottom is exposed
    • The base of the keyboard will be tethered to the device by a piece of silver cable ribbon. Tearing this piece away from the keyboard quickly can damage the device.
    • Use your fingers to gently disconnect the silver cable ribbon from the palm rest.
结论
4等其他人完成本指南。
团队
UW Tacoma, Team 1-3, Rose Fall 2016 UW Tacoma, Team 1-3, Rose Fall 2016 的会员
UWT-ROSE-F16S1G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,429
