跳转到主内容
Asus K53E-BBR3 RAM Replacement
你所需要的
  1. Asus K53E-BBR3 RAM Replacement, Battery: 步骤 1 中的图像 1,3 Asus K53E-BBR3 RAM Replacement, Battery: 步骤 1 中的图像 2,3 Asus K53E-BBR3 RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 RAM Replacement, Back Panel: 步骤 2 中的图像 1,1
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 RAM Replacement: 步骤 3 中的图像 1,1
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • After sliding down the back panel you will see three individual compartments with different components. The one to the far right is the RAM.
  5. Asus K53E-BBR3 RAM Replacement: 步骤 5 中的图像 1,3 Asus K53E-BBR3 RAM Replacement: 步骤 5 中的图像 2,3 Asus K53E-BBR3 RAM Replacement: 步骤 5 中的图像 3,3
    • To remove the RAM stick, locate the silver tabs holding the stick in place.
    • Move the silver tabs so that the detents are no longer holding the RAM in place. Once you've done this, the RAM will pop up and out.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 1-1, Catania Fall 2016 UMass Dartmouth, Team 1-1, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 680
